Defining material properties
Hi Everybody,
How can I define the following thermal conductivity in COMSOL 3.5a
k=10+0.0014*T if T<780
k=12+0.0013*T if 780<T< 1672
k=210-0.1*T if 1672<T<1727
k=8 +0.01*T if 1727<T
Is it possible to give conditional material properties?
If someone helps me, I will appreciate it a lot..
Thanks.
2 Replies Last Post 9 mars 2011, 12:14 UTC−5
Posted: 1 decade ago 9 mars 2011, 10:34 UTC−5
Write it into logical expression should work?
k=(10+0.0014*T)*(T<780)+(12+0.0013*T)*(T>780&&T<1672)+(210-0.1*T)*(T>1672&&T<1727)+(8 +0.01*T)*(T>1727)
Write it into logical expression should work? k=(10+0.0014*T)*(T780&&T1672&&T1727)
Posted: 1 decade ago 9 mars 2011, 12:14 UTC−5
Thank you,
I will try the logical expressions.
Thank you, I will try the logical expressions.
