how to make part of ylabel to subscript or superscript
Hi all,
I have a simple question. when I plot for instance fw versus Sw and I want to put labels for the axis, how can I set xlabel Sw (w as subscript)?
by the way, I'm using comsol 3.5a.
Many thanks,
Elham
3 Replies Last Post 26 sept. 2014, 11:00 UTC−4
Posted: 1 decade ago 8 mars 2011, 15:19 UTC−5
Check your doc, more precisel the guide.pdf search for "ADJUSTING THE PLOT TITLE AND AXIS" p468 for me
You gain a lot of time if you "index" you pdf doc files with a Google or MS file indexer
Hi Check your doc, more precisel the guide.pdf search for "ADJUSTING THE PLOT TITLE AND AXIS" p468 for me You gain a lot of time if you "index" you pdf doc files with a Google or MS file indexer -- Good luck Ivar
Posted: 1 decade ago 9 mars 2011, 05:15 UTC−5
Thank you Ivar; I got it.
Elham
Thank you Ivar; I got it. Regards, Elham
Posted: 1 decade ago 26 sept. 2014, 11:00 UTC−4
See "Using Special Formats and Symbols in Titles"
For superscript use <SUP> </SUP>
-DW
See "Using Special Formats and Symbols in Titles" For superscript use -DW
