Understanding and fixing the singularity error
I have been working with microwave plasmas recently. Everything worked perfectly fine until I decided to add a metal contact boundary condition with a sinusoidal current (Asinwt).
Now I get a singularity error no matter what I change or do. The model runs perfectly when the current equals 0. So I think the problem is not with the boundary conditions since I just added the metal contact condition and changed nothing else.
This is the error that I get:
Repeated error test failures. May have reached a singularity
Time : 3.945307058587785e-008
Sorry, I can't upload the model due to " File extension error".
I have no Idea what I am doing wrong. Any help would be very much appreciated.
Thanks.
1 Reply Last Post 20 oct. 2017, 08:47 UTC−4
Hello Jessie Frost
Posted: 7 years ago 20 oct. 2017, 08:47 UTC−4
When you receive such error, at first try to adjust "Relative tolerance" parameter from 1e-2 down to 1e-6. Hope it'll help
Hi, When you receive such error, at first try to adjust "Relative tolerance" parameter from 1e-2 down to 1e-6. Hope it'll help
