access components of a vector
I am newbie for comsol. I want to integrate the cross product between Electric field components (Ex,Ey,Ez) and radius vector (r -originating from the origin [0,0,0]) defined as r=sqrt(x^2+y^2+z^2) inside a domain (volume). integral ( r x E)
I am unable to figure out how to use the vector components of radius vector r. So that I am able to define them as global variable by evaluating the following expression.
| i j k |
| rx ry rz |
| Ex Ey Ez |
Later I could integrate them on the desired domain.
P.S. I am using comsol version 3.5a.
3 Replies Last Post 6 mars 2011, 08:10 UTC−5
Posted: 1 decade ago 6 mars 2011, 06:21 UTC−5
I'm not fully following you:
rx,ry,rz isn't that your x,y,z ?
and the integration of a cross product isn't it a vector integration so its three integrations ?
of the type (int(y*Ez-z*Ey), -int(x*Ez-z*Ex), int(x*Ey-y*Ex))
I might have got the cross product up side down, pls check, and I might have completely missed your poit ;)
Hi I'm not fully following you: rx,ry,rz isn't that your x,y,z ? and the integration of a cross product isn't it a vector integration so its three integrations ? of the type (int(y*Ez-z*Ey), -int(x*Ez-z*Ex), int(x*Ey-y*Ex)) I might have got the cross product up side down, pls check, and I might have completely missed your poit ;) -- Good luck Ivar
Posted: 1 decade ago 6 mars 2011, 06:28 UTC−5
Thanks Ivar for the answer. I must admit it turned out to be a silly question ;).
Posted: 1 decade ago 6 mars 2011, 08:10 UTC−5
no questions are silly, replies might b, often one manage to give onself a reply by asking the question ;)
Hi no questions are silly, replies might b, often one manage to give onself a reply by asking the question ;) -- Good luck Ivar
