Non liear solver convergence problem when mesh is increased...FSI
Posted 3 mars 2011, 16:17 UTC−5 Studies & Solvers Version 4.1 1 Reply
I run FSI model with low mesh size. This simulation is done without any errors.
And I increase the size of mesh in both of fluid and solid domain. But when I increased I got error in the middle of calculation as following;
Nonlinear solver is not converged.
The quality of mesh is similar between two cases with the range of 0.3 - 0.8 of tetrahedral elements.
This situation is not a first time in FSI. Only with solid modeling this also happened when mesh increased.
I don't understand this because in general it is better with high mesh.
Is there anyone who have a similar situation?
P.S. The server has a enough memory to load all calculation thus I used the direct method to simulation in FSI and only solid moel.
1 Reply Last Post 4 mars 2011, 01:17 UTC−5
