3D structural model converging or badly defined?
Posted 2 mars 2011, 12:39 UTC−5 3 Replies
I have a 3D structural model with about 1M DoF.
It's currently running on a workstation with 2 Xeon processors Quad-Core (Total 8 cores) with 24GB of RAM.
It's been running for 24 hours and I'm wondering if I should just kill the solver and try to redefine my model or is it "normally" solving it.
Here is what the log looks like for the moment:
Iter ErrEst Damping Stepsize #Res #Jac #Sol
Warning: Inverted mesh element near coordinates (0.00121095, 0.0993358, 0.00215987)
1 0.00044 0.0100000 0.00045 4 1 4
2 0.00091 0.0039136 0.00092 5 2 6
3 0.00052 0.0128438 0.00053 6 3 8
Warning: Inverted mesh element near coordinates (0.00121319, 0.0995191, 0.00216386)
4 0.00053 0.0131304 0.00054 7 4 10
5 0.0011 0.0030533 0.0011 8 5 12
6 0.001 0.0104015 0.0011 9 6 14
7 0.0015 0.0055642 0.0015 10 7 16
8 0.0013 0.0010043 0.0013 12 8 19
9 0.0041 0.0001691 0.0041 13 9 21
10 0.0062 0.0002497 0.0062 14 10 23
11 3.5e+007 0.7500000 0.08 16 11 26
12 1.3 0.0001000 1.3 20 12 31
13 0.93 0.0001000 0.93 22 13 34
14 1.2 0.0001000 1.2 23 14 36
15 1.2 0.0001000 1.2 24 15 38
16 1 0.0001648 1 25 16 40
17 1.6 0.0001000 1.6 26 17 42
18 4e+007 0.7500000 1.7 28 18 45
19 0.95 0.0100000 1 31 19 49
Warning: Inverted mesh element near coordinates (0.00121766, 0.0998856, 0.00217183)
20 1.3e+006 0.7500000 1.6 35 20 54
Looking at the error estimate (ErrEst), it seems to oscillate a lot so I'm wondering if it's worthwhile to let it run or if I should try to redo my model. There's a lot of "inverted mesh element" warning but since I had a lot of difficulty just to mesh my model without ending up with 4M DoF...I'm rather pleased with the mesh as it is.
What do you think?
Is it a "normal" run or is it going nowhere due to the error oscillating that much?
(It's running the Nonlinear solver and MUMPS)
Also, should I restrict COMSOL to just use 4-cores instead of 8 in order to get more RAM per core (since I "only" have 24GB).
Thanks.
What do you think?
Thanks.
3 Replies Last Post 2 mars 2011, 15:00 UTC−5
