Animation with deformed structure
Hi all,
I succeeded to make Animation of changing displacement.
However, It doesn't contains displacement deformation.
So the animation contains rainbow color change only.
How can I express deformation in animation.
Thank you~~
4 Replies Last Post 9 juil. 2017, 14:29 UTC−4
Posted: 1 decade ago 23 févr. 2011, 01:48 UTC−5
did you turn on the deformation for your surface plot (right click Add Defomrations ?
Hi did you turn on the deformation for your surface plot (right click Add Defomrations ? -- Good luck Ivar
Posted: 1 decade ago 23 févr. 2011, 03:07 UTC−5
Right. I did it.
I turned on deformation on surface.
What I did is that
left click deformation-> push 'player button' on the top-right
->player1 occurs in 'Report' and its graphic is deformed.
-> right click 'Report' and select 'Animation'
-> no deformation occur in Animation
Did I do wrong?
Thank you
Hi, Right. I did it. I turned on deformation on surface. What I did is that left click deformation-> push 'player button' on the top-right ->player1 occurs in 'Report' and its graphic is deformed. -> right click 'Report' and select 'Animation' -> no deformation occur in Animation Did I do wrong? Thank you
Posted: 1 decade ago 23 févr. 2011, 03:13 UTC−5
I do not know ;)
I just tried, it worked but probably I'm using a different example ?
Do you have latest patch/update ? Not sure it's related
Hi I do not know ;) I just tried, it worked but probably I'm using a different example ? Do you have latest patch/update ? Not sure it's related -- Good luck Ivar
Posted: 8 years ago 9 juil. 2017, 14:29 UTC−4
I checked your Comsol model, unfortunately, the animation with deformation can display with solid.disp, not with other output like solid.mises
