Sergei Yushanov
Certified Consultant
7 years ago
1 juin 2017, 12:59 UTC−4
Hiroki,
As you say, capacitance matrix is obtained by exciting one terminal at a time, not by applying voltage at several terminal simultaneously - see example problems
www.comsol.com/model/touchscreen-simulator-30841
www.comsol.com/model/download/420531/Capacitance_Matrix_2Spheres.pdf
Sergei
Hiroki,
https://www.comsol.com/model/touchscreen-simulator-30841
https://www.comsol.com/model/download/420531/Capacitance_Matrix_2Spheres.pdf
Sergei
Sergei Yushanov
7 years ago
1 juin 2017, 13:31 UTC−4
Hiroki,
You can use Terminal sweep option to calculate capacitance matrix for multiple plates in a single run, as shown in the attached slides.
Sergei
Hiroki,
Sergei
7 years ago
6 juin 2017, 04:04 UTC−4
Thank you very much Sergei, but could you give me an example file where we have this parametric sweep. I am not familiar with the parametric sweeping . As per the slide i have activated the terminal sweep option, then the slide does not explain well , how to perform this operation.
Sergei Yushanov
7 years ago
6 juin 2017, 08:00 UTC−4
Hiroki,
Attached is example model calculating Maxwell capacitance matrix for coplanar waveguide.
Sergei
Hiroki,
Sergei
7 years ago
6 juin 2017, 23:06 UTC−4
Updated:
7 years ago
6 juin 2017, 23:19 UTC−4
Sergei,
Thank you very much.That was helpful. I have just one last question; In your example, why do the Maxwell capacitance and the mutual capacitance give absolutely the same result ?
I appreciate your help.
Sergei,
Sergei Yushanov
7 years ago
7 juin 2017, 08:00 UTC−4
Hiroki,
Not sure why you are saying that mutual and Maxwell matrices are the same - they are different, as shown in the attached image.
Sergei
Hiroki,
Sergei
7 years ago
8 juin 2017, 02:21 UTC−4
Updated:
7 years ago
10 juin 2017, 02:24 UTC−4
Sergei,
Sure , in your file, you have plotted the first one under Transformation: None
the second one is under Transformation: Maxwell to mutual
Please try the following option under Transformation : mutual to Maxwell, you will get exactly the same answer for, may be that is an error or something I guess.
Transformation: Maxwell to mutual and mutual to Maxwell.
Sergei,
7 years ago
10 juin 2017, 02:16 UTC−4
Dear Sergei,
Thank you very much
Now I am trapped in a weird situation. I have a co planar wave guide where I want to calculate the capacitance with two pads. I have been getting asymmetric and positive elements on the capacitance matrix(non diagonal elements). Do you have some idea why?
C11=221fF
C12=-2.6fF
C13=+5.33fF
C21=-2.61fG
C31=+3.99fF
Dear Sergei,
Thank you very much
C11=221fF
C12=-2.6fF
C13=+5.33fF
C21=-2.61fG
C31=+3.99fF
