Parametric sweep where the range of one parameter depends on the other
Posted 31 mai 2017, 05:47 UTC−4 MEMS & Nanotechnology, MEMS & Piezoelectric Devices Version 5.2 0 Replies
angle - range(30[deg],10[deg],60[deg])
tsupp - range(t0*cos(angle),(t1-(t0*cos(angle)))/5,t1)
t0 in this case is 100nm and t1 is 130nm.
This, however, doesn't work. I think the range of tsupp is defined once for one angle, and when that angle changes, the range of tsupp is not updated, leading to a broken geometry. Is there a method that will allow me to sweep through both of these parameters?
Thank you in advance!
Hello Thomas Middelburg
