Time Dependent Solver
Posted 23 mai 2017, 04:35 UTC−4 Heat Transfer & Phase Change, Studies & Solvers Version 5.3 0 Replies
Can anyone explain the methodology for the relative tolerance for a time-dependent study? For example, the default value is 0.01 (physics based tolerance) and if I change the value to 1e-9 then the solution takes much longer with not much change in the temperature profile.
Daipayan
Hello Daipayan Sarkar
