Viscous flow boundary question
I am trying to simulate a region of a deforming viscous solid (ie the lithosphere of Venus). I would like to specify the equivalent of a horizontal strain boundary condition - with the horizontal velocity fixed and the vertical velocity free. Any suggestions? I am using the standard Laminar Flow physics.
Phil
3 Replies Last Post 23 févr. 2011, 01:54 UTC−5
Posted: 1 decade ago 21 févr. 2011, 01:39 UTC−5
I would study the underlaying COMSOL equations of noslip, and moving wall BC's (and perhaps some of the others) I believe you will find your need therein, if not by tweaking these somewhat
Hi I would study the underlaying COMSOL equations of noslip, and moving wall BC's (and perhaps some of the others) I believe you will find your need therein, if not by tweaking these somewhat -- Good luck Ivar
Posted: 1 decade ago 22 févr. 2011, 20:48 UTC−5
Thanks for the suggestion Ivar,
I think I see what I need in the slip wall BC. The default sets the normal velocity to zero while leaving the tangential free. I can adjust the normal to a fixed velocity as in the moving wall.
Can anyone lead me toward resources that will instruct me on how to create a user-defined boundary condition? Can this be done within the COMSOL GUI?
Phil
Thanks for the suggestion Ivar, I think I see what I need in the slip wall BC. The default sets the normal velocity to zero while leaving the tangential free. I can adjust the normal to a fixed velocity as in the moving wall. Can anyone lead me toward resources that will instruct me on how to create a user-defined boundary condition? Can this be done within the COMSOL GUI? Phil
Posted: 1 decade ago 23 févr. 2011, 01:54 UTC−5
study the existing BC and add weak contributions at will
You might need to turn on the Main Physics Node - Advanced Settings - Show all model inputs
Hi study the existing BC and add weak contributions at will You might need to turn on the Main Physics Node - Advanced Settings - Show all model inputs -- Good luck Ivar
