Sheet metal bending - spring back effect
Posted 17 mars 2017, 12:26 UTC−4 Materials, Studies & Solvers, Structural Mechanics Version 5.2 2 Replies
I am trying to make an elastoplastic 2D simulation of sheet metal bending to observe different spring back in various materials. I want to use V-bending proccess since we have a fixture to do the same experiment in the future to check for validity.
I would like to keep it as simple as possible. I am using some data that I have from tensile experiments for different materials and setting simple stress-strain curves with 3 points to vary the hardening. I also set the load/load removal along with auxiliary sweep for the load stepping so the spring back could be observed after the removal of the load.
I am not sure how I should define the contact between the parts. I tried to use contact pairs but I don't know if it is correct. Unfortunately cannot find much about this specific topic on the internet or in this forum (tried to use 3 point bending that someone used which could be similar but didn't succeed much)
2 Replies Last Post 23 mars 2017, 12:49 UTC−4
