Creating a 3D object using faces and vertices.
Hi all,
I am trying to create a 3D object using COMSOL script.
My object has a complex and arbitrary geomtry.
The geometry is defined using two matrices: faces and vect.
I can display the object using MATLAB but still ave difficulties in creating the object in COMSOL.
I pasted my script below (This script is based on the discussion between Chan and Pasquale).
nface=size(faces,1);
fObj=cell(1,nface);
for I=1:nface
f=faces(I,:);
localVertex=vert(f,:);
X=[localVertex(1,1),localVertex(2,1); localVertex(4,1),localVertex(3,1)];
Y=[localVertex(1,2),localVertex(2,2); localVertex(4,2),localVertex(3,2)];
Z=[localVertex(1,3),localVertex(2,3); localVertex(4,3),localVertex(3,3)];
fObj{I}=face3(X,Y,Z);
end
solidObj=geomcoerce('solid',fObj);
If I run the script, I have a following error:
??? Java exception occurred:
Exception: com.femlab.jni.FlNativeException: Internal error geometry decomposition
Messages: Internal error geometry decomposition
Stack trace:
at csgsurfisect.cpp, row 543, ()
at com.femlab.geom.Geom.coerce(Native Method)
at com.femlab.geom.Geom.b(Unknown Source)
at com.femlab.geom.Geom.coerce(Unknown Source)
Error in ==> geomcoerce at 54
jptr = com.femlab.geom.Geom.coerce(jgeoms, sdim, totype, prop, outprop);
Error in ==> seg_salt_data_process10 at 43
Could you suggest any possible solution for this problem or a btter way to generate a 3D object defined by faces and vertices in COMSOL? Attached is my sample faces and vertice matrices.
In advance, I appreciate your help.
Evan
3 Replies Last Post 23 févr. 2010, 04:01 UTC−5
Posted: 2 decades ago 1 nov. 2009, 03:22 UTC−5
have you tried to play with the order or the points/vertices?
Comsol has a given way to count the vertices, you might have an inverted surface.
I have had some difficulties with this before, unfortunately I have not found any simple clear explanation/examples how to get this vertex oder "correct". And I gave up using Comsol geoemetries some years ago, it's much quicker with the CAD link to SolidWorks (BUT I admit COMSOL written geoemtries are nice for simple cases and are more powerfull, as well as these excercices allows you to read in and translate ANSYS or NASTRAN data files which is lacking in COMSOL today, you can only read in the meshes from NASTRAN but not get in the the minimum of material data, groups or shell/beam properties)
Now it might be another error you are hitting, so do not only search in the direction given above.
Hi have you tried to play with the order or the points/vertices? Comsol has a given way to count the vertices, you might have an inverted surface. I have had some difficulties with this before, unfortunately I have not found any simple clear explanation/examples how to get this vertex oder "correct". And I gave up using Comsol geoemetries some years ago, it's much quicker with the CAD link to SolidWorks (BUT I admit COMSOL written geoemtries are nice for simple cases and are more powerfull, as well as these excercices allows you to read in and translate ANSYS or NASTRAN data files which is lacking in COMSOL today, you can only read in the meshes from NASTRAN but not get in the the minimum of material data, groups or shell/beam properties) Now it might be another error you are hitting, so do not only search in the direction given above. Good luck Ivar
Posted: 2 decades ago 23 févr. 2010, 04:01 UTC−5
Hello
Did you find a solution for your problem ?
I didn't understand why you have 4 dimensions ....
fObj=cell(1,nface);
for I=1:nface
f=faces(I,:);
localVertex=pts(f,:);
X=[localVertex(1,1),localVertex(2,1),localVertex(3,1)];
Y=[localVertex(1,2),localVertex(2,2),localVertex(3,2)];
Z=[localVertex(1,3),localVertex(2,3),localVertex(3,3)];
end
Error: Internal geometry error.
Error in built-in function javaObject.
bsplinesurf3 80 jptr=com.femlab.geom.BSplineSurf3(prop);
face3 75 obj = bsplinesurf3(p,q,u,v,x,y,z,varargin{4:end});
do you know where can it come from ?
thanks
Hello Did you find a solution for your problem ? I didn't understand why you have 4 dimensions .... nface=size(faces,1); fObj=cell(1,nface); for I=1:nface f=faces(I,:); localVertex=pts(f,:); X=[localVertex(1,1),localVertex(2,1),localVertex(3,1)]; Y=[localVertex(1,2),localVertex(2,2),localVertex(3,2)]; Z=[localVertex(1,3),localVertex(2,3),localVertex(3,3)]; fObj{I}=face3(X,Y,Z); end Error: Internal geometry error. Error in built-in function javaObject. bsplinesurf3 80 jptr=com.femlab.geom.BSplineSurf3(prop); face3 75 obj = bsplinesurf3(p,q,u,v,x,y,z,varargin{4:end}); do you know where can it come from ? thanks
