Integration calling 2 different solutions?
Hi everyone,
Is it possible to do an integration that calls variables from different solutions?
I am trying to do an inner product of two solutions, (the same geometry with different parameters), to find their correlation.
The variables are stored in different solutions (I uses parameter sweep). When I try to do "Derive Values" -> "Volume integration," the data set and parameters have to be specified.
So is it possible to call them from different solutions, and putting them together in the integral expression?
Many thanks!
2 Replies Last Post 21 févr. 2017, 06:29 UTC−5
Posted: 8 years ago 21 févr. 2017, 03:48 UTC−5
Use the withsol() operator. Check out the documentation for more info.
Henrik
Hi, Use the withsol() operator. Check out the documentation for more info. Regards, Henrik
Posted: 8 years ago 21 févr. 2017, 06:29 UTC−5
That's awesome! Thank you!
TW
That's awesome! Thank you! Regards, TW
