Iterative solving utilizing local variables to avoid circular variables
Hello all,
I have a circular variable issue for local variables, and am interested in knowing if there is an iterative solver that can solve this issue.
Ex of problem:
(int1 is an interpolation table that uses T as the argument)
C = int1(T)
T = C * y
Can an iterative solver be used to first evaluate a solution using a constant value for a local variable, in place of a function that creates a circular dependency, then reevaluate the solution using a function that uses the previous solution for a local variable?
ex:
1st run: C = 1500
T = C * y
2nd run: C_new = int1(T)
T_new1 = C * y
3rd run: C_new = int1(T_new1)
T_new2 = C * y
with this process running until T_new_n = T_new_n-1 i.e. until the new solution and previous solution converge?
Can/how could this be implemented?
Thank you in advance.
0 Replies Last Post 20 févr. 2017, 15:57 UTC−5
Hello Sean Moser
