Problem importing the data file with CAD import module
Hello every one,
when i try to import the scalar expressions for open_pipe model (under acoustic module) from cad data file, i get the following errors
Erro : 3015
Unrecognised file type.
Exception:
com.femlab.util.FlException: Unrecognized file type.
Stack trace:
at com.femlab.geom.GeomImportRunnable.a(Unknown Source)
at com.femlab.geom.GeomImportRunnable.usesImportTol(Unknown Source)
at com.femlab.commands.CadImportCmd.evalOnServer(Unknown Source)
at com.femlab.commands.FlCommand.runServerCode(Unknown Source)
at com.femlab.server.ServerProxy.eval(Unknown Source)
at com.femlab.commands.FlCommand.a(Unknown Source)
at com.femlab.commands.FlCommand.eval(Unknown Source)
at com.femlab.commands.a.a(Unknown Source)
at com.femlab.gui.dialogs.ImportCADAccessory.a(Unknown Source)
at com.femlab.gui.dialogs.bv.b(Unknown Source)
at com.femlab.gui.dialogs.bj.a(Unknown Source)
at com.femlab.gui.FlProgressThread.run(Unknown Source)
at com.femlab.util.i.run(Unknown Source)
at com.femlab.util.aa.run(Unknown Source)
I am just the beginner in comsol environment..
Please help me to solve this problem...
2 Replies Last Post 27 oct. 2016, 23:24 UTC−4
Hello Kunal Parikh
Posted: 1 decade ago 30 janv. 2014, 06:44 UTC−5
Hi kunal Parikh,
Check your source file, I think that all are corrupted. 3015 error indicates that unable to find source path. So I would like to suggest you give perfect source path and Import once more properly.
I hope it can help you.
Natalie Hutchins
Senior CAD Engineer
(www.indiacadworks.com/)
Hi kunal Parikh, Check your source file, I think that all are corrupted. 3015 error indicates that unable to find source path. So I would like to suggest you give perfect source path and Import once more properly. I hope it can help you. Thanks Natalie Hutchins Senior CAD Engineer (http://www.indiacadworks.com/)
Posted: 8 years ago 27 oct. 2016, 23:24 UTC−4
Hi Natalie
I want to import a 2D CAD file for instance DXF or DWG in a 2D COMSOL geometry.
But I get the error 'The file contains no geometry objects of the requested type.'
Do you know how can I solve it?
Your reply will be greatly appreciated. Thanks a lot.
Wei Rui
Hi Natalie I want to import a 2D CAD file for instance DXF or DWG in a 2D COMSOL geometry. But I get the error 'The file contains no geometry objects of the requested type.' Do you know how can I solve it? Your reply will be greatly appreciated. Thanks a lot. Wei Rui
