orthogonal view
How to see an object orthogonally? I am not sure if I am using the correct terminology but what I mean to say is: when you look at a 3D geometry in the x-y, y-z or z-x planes, COMSOL shows them in a perspective (?) view. For example, if I have a 3D pipe, and I am looking at it from the side view, I only want to see two concentric circles instead I am seeing 4 concentric circles. I started having this issue when I started using the 4X COMSOL versions. In 3.5 there was a button to change the view. If my question is not clear please let me know and I will try to explain it using a picture.
Sirisha
5 Replies Last Post 17 août 2015, 13:30 UTC−4
Posted: 1 decade ago 30 janv. 2011, 03:52 UTC−5
that is the Perspective or projection mode see the "view" subnode.
Note you might have several views and even some with hidden geoemtries OR entities
Hi that is the Perspective or projection mode see the "view" subnode. Note you might have several views and even some with hidden geoemtries OR entities -- Good luck Ivar
Posted: 1 decade ago 3 févr. 2015, 13:02 UTC−5
Did you figure this out. I'm trying to achieve the same thing with no luck.
Posted: 1 decade ago 3 févr. 2015, 13:07 UTC−5
Figured it out. Thanks
Posted: 10 years ago 23 juin 2015, 04:10 UTC−4
Can you share how you did it?
[QUOTE] Figured it out. Thanks [/QUOTE] Can you share how you did it?
Posted: 10 years ago 17 août 2015, 13:30 UTC−4
Go to Model / Definitions / View / Camera
then change Perspective to Orthographic under Projection.
Go to Model / Definitions / View / Camera then change Perspective to Orthographic under Projection.
