Add a part to the part library
Is it possible to add your own parts to the comsol part library? I want to create a part in one model, and then use it in other models without using that first model as a template. I see that I can export the part as an .mphbin, and I know I can import that in other models, but the import node is not nearly as useful as a part with all the geometry sub-nodes defined.
Jayse Langdon
1 Reply Last Post 9 févr. 2017, 02:39 UTC−5
Posted: 8 years ago 9 févr. 2017, 02:39 UTC−5
A part is contained in an .mph file.
You create a part under Global Definitions -> Geometry Parts and then just save the file..
Open one of the parts shipped with the product (you will find it in a location like C:\Program Files\COMSOL\COMSOL52a\Multiphysics\parts\COMSOL_Multiphysics\Examples ) to see how a part is structured.
Henrik
Hi, A part is contained in an .mph file. You create a part under Global Definitions -> Geometry Parts and then just save the file.. Open one of the parts shipped with the product (you will find it in a location like C:\Program Files\COMSOL\COMSOL52a\Multiphysics\parts\COMSOL_Multiphysics\Examples ) to see how a part is structured. Regards, Henrik
