Defining time dependent heat flux
Hi all,
In my model, of moving heat load, i want to see the effect of heating as well as cooling on specimen.
for this i want to define heating and cooling time separately in the same simulation, how i should write conditional statement.
Thank you.
4 Replies Last Post 9 févr. 2017, 04:39 UTC−5
Posted: 8 years ago 7 févr. 2017, 12:40 UTC−5
If you are using convective heat flux.. and changing ambient temperature. then you can use ambient temperature as a step function or else type this expression in ambient temperature field . if(t<heatingtime, T_hot, T_cold).
Posted: 8 years ago 8 févr. 2017, 22:50 UTC−5
Thank you for your quick reply.
In the model, I am applying a heat source which is moving with certain velocity and heating the specimen, when i am defining the time study the heat source is running for the defined time and by that time only heating is happening which i don't want. I want to stop the heat source functioning after certain time to diffuse the heat. for this i have to define heating time and cooling time in same simulation.
Thank you for your quick reply. In the model, I am applying a heat source which is moving with certain velocity and heating the specimen, when i am defining the time study the heat source is running for the defined time and by that time only heating is happening which i don't want. I want to stop the heat source functioning after certain time to diffuse the heat. for this i have to define heating time and cooling time in same simulation.
Posted: 8 years ago 9 févr. 2017, 02:40 UTC−5
Maybe this blog post will give you some ideas:
www.comsol.se/blogs/how-to-make-boundary-conditions-conditional-in-your-simulation/
Henrik
Hi, Maybe this blog post will give you some ideas: https://www.comsol.se/blogs/how-to-make-boundary-conditions-conditional-in-your-simulation/ Regards, Henrik
Posted: 8 years ago 9 févr. 2017, 04:39 UTC−5
Thank you for your response.
Sujit
Thank you for your response. Regards, Sujit
