Generalised Electrostatics
I just downloaded the Faraday cage model from www.comsol.com/community/exchange/104/ and I noticed that it was created using the Generalised Electrostatics model. The problem is I can't seem to find this model in the new model dialogue.
Where can I find the Generalised Electrostatic model in the new model navigator?
1 Reply Last Post 28 janv. 2011, 07:27 UTC+1
Posted: 1 decade ago 28 janv. 2011, 07:27 UTC+1
there are many things that have changed with V4, including naming and the way to split phsics versus previous "application" modes. The best way I know is to load the model in its respective version, check and list the dependent variables, and search in the new version where yu solve for the same ones, than check the equations. In V4 you can achieve some of th previous application modes in several ways, dependng of what else (other physics) you plan to model
Hi there are many things that have changed with V4, including naming and the way to split phsics versus previous "application" modes. The best way I know is to load the model in its respective version, check and list the dependent variables, and search in the new version where yu solve for the same ones, than check the equations. In V4 you can achieve some of th previous application modes in several ways, dependng of what else (other physics) you plan to model -- Good luck Ivar
