2D corona Discharge
Hi everyone
i'm trying to simulate corona discharge between two electrodes in comsol 5.2
the mesh is triangular with boundary layer mesh.
i have built my model based on the example in the software's application libraries
but with different meshes the following errors have occured:
can anyone help me with this? i would be very appreciated
1 Reply Last Post 8 févr. 2017, 09:41 UTC−5
Posted: 8 years ago 8 févr. 2017, 09:41 UTC−5
I have the same problem in plasma DBD discharge.
I have used a very very small mesh ==> the calculation stop in "matrix factorization" after some milliseconds of physical time.
I have used an iterative solver ==> my calculation converged but i have false results
Do you have find a solution ?
Hi, I have the same problem in plasma DBD discharge. I have used a very very small mesh ==> the calculation stop in "matrix factorization" after some milliseconds of physical time. I have used an iterative solver ==> my calculation converged but i have false results Do you have find a solution ? Good luck
