Optimization with Particle Tracing Module
Hi everyone,
As mentioned, I would like to use COMSOL's optimization module to apply to Particle Tracing for Fluid Flow physics interface. The model refers to "Acoustic Levitator" of the model libraries. The model solves the Pressure Acoustics, Frequency Domain to calculate the pressure p, then apply this interface on Particle Tracing for Fluid Flow to trace the trajectories of the particles. Two studies are used included: Study 1 for Frequency Domain (calculate pressure in Acoustic Pressure, Frequency Domain interface), Study 2 for Time Dependent (trace the particle's position in Particle Tracing for Fluid Flow).
The optimization is maximizing Laplacian of acoustophoretic potential energy (in Particle Tracing Module) at a specific point. To do that, I've used the probe objective with the expression d(d(fpt.Urad),x),x)+d(d(fpt.Urad),y),y) with a random probe coordinates. I've also used the Global Control Variable to define the phase of the transducer (initial value= 60[deg]; bound range from -180[deg] to 180[deg]). However, when computing, it is said the "Only the BDF solver support analytic gradient". Therefore, I try "BDF" and "Initialization only" in the "Time-Dependent Solver" but none of them works.
I' ve tried to plot the particle trajectories with the above expression and the plot works well. I suspect the problem is because of the mathematical expression of potential energy fpt.Urad contains two terms that are in the form of real(a*conj(b)) but I'm not so sure. So the question is why I can't perform the optimization and do you have any suggestions?
I would very much appreciate if anyone could help me. The attached below are some settings in the model.
Sincerely,
Quoc
1 Reply Last Post 28 mars 2017, 10:02 UTC−4
Hello Quoc Pham
Posted: 8 years ago 28 mars 2017, 10:02 UTC−4
I'm also trying to do that for an electrostatics problem. I didn't find any physics interface for solving equation of motion for particles. So I'm trying to implement the equation motion of particles using the mathematics module with force calculated from the electric field. But I'm confused about the physics interface I should be using. Any idea what I should use? Is there an easier way to do this?
Edit: I found the module. Sorry for bothering you.
I'm also trying to do that for an electrostatics problem. I didn't find any physics interface for solving equation of motion for particles. So I'm trying to implement the equation motion of particles using the mathematics module with force calculated from the electric field. But I'm confused about the physics interface I should be using. Any idea what I should use? Is there an easier way to do this? Edit: I found the module. Sorry for bothering you.
