Undefined variable on symmetry boundaries
Posted 13 janv. 2017, 02:25 UTC−5 0 Replies
/*****Error********/
Cannot evaluate expression.
Undefined variable.
- Variable: comp1.ewfd.Ey - Geometry: geom1 - Domain: 44
- Expression: comp1.ewfd.Ey
I have figured out that the error is caused by the field some times not being evaluated at the symmetry boundaries, i.e. if i shift the evaluation slight away (e.g. by evaluating the xz plane at y = 1 nm rather than y = 0), the error vanishes. I can also "fix" the error by running the simulation multiple times for slightly different values of w (e.g. i start with w=5000 nm, then try w=5100 nm and so on) until i "get lucky" and the export succeeds.
My guess is that it all boils down to the location of mesh nodes relative to the symmetry boundary. However, i am not sure how to fix the problem properly. Is there any way to force COMSOL do "include" the boundary in the domain which is being evaluated?
Cheers,
Emil
Hello Emil Eriksen
