Gas velocity in a tube under isothermal heating
Posted 12 janv. 2017, 09:02 UTC−5 Fluid & Heat, Heat Transfer & Phase Change Version 5.2a 0 Replies
I'm working on modelling a gas flow inside a quartz tube. the gas flows from room temperature zone (25 cm long) and enters a hot zone (75 cm at 1000 C) . according to calculation the mean velocity of gas suppose to be some thing like 15 m/s but cmosol shows 1cm/s, I thing the effect of temperature on velocity doesn't calculated, so pleae can you help?
Regards
Samir
Hello Samir Hilfi
