How to do "if---else" in comsol GUI?
How to write the equivalent "phi" expression in GUI according to the codes below ?
if x==0
if y>0
phi=0.5*pi
else
phi=-0.5*pi
else if x>0
if y>0
phi=atan(y/x)
else
phi=2*pi+atan(y/x)
else
phi=pi+atan(y/x)
ps: x, y are the space independent variables, phi is a user-defined variable
my ways is: phi=(x==0&&y>0)*(0.5*pi)+(x==0&&y<=0)*(-0.5*pi)+(x>0&&y>0)*(atan(y/x))+(x>0&&y<=0)*(2*pi+atan(y/x))+(pi+atan(y/x)). Is it right? or are there better ones?
1 Reply Last Post 22 janv. 2011, 12:34 UTC−5
Posted: 1 decade ago 22 janv. 2011, 12:34 UTC−5
I have seen the "if()" way, your way and the one replacing the && and ¦¦ by */+ i believe all work, but have newer tested the issue w.r.t speed, have you tried these variants as "functions" and used COMSOL to plot them ? That's my way to test the equations.
Hi I have seen the "if()" way, your way and the one replacing the && and ¦¦ by */+ i believe all work, but have newer tested the issue w.r.t speed, have you tried these variants as "functions" and used COMSOL to plot them ? That's my way to test the equations. -- Good luck Ivar
