Self inductance of brooks coil
I am making some tests with Comsol 4.0a. I want for example to calculate the self inductance of a Brooks coil using the AC/DC module.
You can find more informations and geometry definition about Brooks coil here:
www.nessengr.com/techdata/brooks/brooks.html (I checked the formulas)
If we take,
c = 1 m
then the theoretical self inductance is,
L11 = 2.5491e-6 H
I set up a model similar to the "Helmholtz coil" tutorial (3D, mf, stationary with external current density) and tried to calculate the self inductance using the energy method,
L11=2*Wm/(I0^2)
where,
Wm is the total magnetic energy (mf.intWm)
I0 is the current in the coil
I got,
L11 = 6.1446e-7 H
This value is obviously different from the theoretical one. I enclosed my model if you want to have a look. Any solution ?
2 Replies Last Post 24 janv. 2011, 04:01 UTC−5
Posted: 1 decade ago 21 janv. 2011, 02:00 UTC−5
One little thing, as your J0 is defined w.r.t Parameters, you can also define it as a Parameter (former "Constants" and which are interpreted once at the beginning of a Solver run) the advantage is that you see the resulting value written out, which is often useful, and you can use the J0 as a parameter for a later "parametric sweep" if needed
When I take your model in v4.1 I get :
int3 H.B/(I0^2) (H)
2.4603e-6
Close enough no? Try with infinite elements to get perhaps closer, not even sure, or a finer mesh
But I have reset the mesh to default physics induced (normal), so probably its that there are still a few typos in the equations in V4.0, really use the latest patched 4.1, you will be less frustrated ;)
Hi One little thing, as your J0 is defined w.r.t Parameters, you can also define it as a Parameter (former "Constants" and which are interpreted once at the beginning of a Solver run) the advantage is that you see the resulting value written out, which is often useful, and you can use the J0 as a parameter for a later "parametric sweep" if needed When I take your model in v4.1 I get : int3 H.B/(I0^2) (H) 2.4603e-6 Close enough no? Try with infinite elements to get perhaps closer, not even sure, or a finer mesh But I have reset the mesh to default physics induced (normal), so probably its that there are still a few typos in the equations in V4.0, really use the latest patched 4.1, you will be less frustrated ;) -- Good luck Ivar
Posted: 1 decade ago 24 janv. 2011, 04:01 UTC−5
Hi Ivar,
Thank you for pointing this out. With finner mesh and bigger sphere I got 2.5354e-6H as expected.
Thank you again.
Hi Ivar, Thank you for pointing this out. With finner mesh and bigger sphere I got 2.5354e-6H as expected. Thank you again.
