LiveLink doesn't work
Hi, I'm a comsol beginner and wanted to try Livelink with Creo but in Comsol i always get the Error that comsol can't connect to creo and i should start creo. The problem is creo is already started. How can i connect creo with Comsol?
Romol
1 Reply Last Post 28 nov. 2016, 07:17 UTC−5
Lorant Olasz COMSOL Employee
Posted: 8 years ago 28 nov. 2016, 07:17 UTC−5
Hi Romol,
I recommend that you follow the steps in the following Knowledge Base article:
www.comsol.com/support/knowledgebase/1221/
If the problem remains after that, please contact support to troubleshoot further what could be causing the connection issue.
Lorant
Hi Romol, I recommend that you follow the steps in the following Knowledge Base article: https://www.comsol.com/support/knowledgebase/1221/ If the problem remains after that, please contact support to troubleshoot further what could be causing the connection issue. Best regards, Lorant
