8 years ago
16 nov. 2016, 15:06 UTC−5
Hi Youness,
It is possible if you split the two PDEs into two components and use component coupling for data exchange between the two components. For more information please contact support@comsol.com, or you can log in to your COMSOL Access account, and submit support cases from there.
Mao Mao, PhD
COMSOL Inc.
Hi Youness,
Mao Mao, PhD
COMSOL Inc.
Henrik Sönnerlind
COMSOL Employee
8 years ago
17 nov. 2016, 02:45 UTC−5
If your problem is one-way coupled, you could also solve the problem using two separate studies, since you can select a different mesh for each study.
Henrik
Henrik
8 years ago
17 nov. 2016, 09:26 UTC−5
Thank you Mao and Henrik for the replies. The coupling is two-way one. I tried Mao's solution and it seems working.
7 years ago
11 août 2017, 08:23 UTC−4
Updated:
7 years ago
Hello Henrik
Is there any limitation or relation between two meshes?!
Because when i choose my second mesh finer (while the first one is coarse) I face an error, but with a fine mesh it goes well!
For your information I'm using data from corse mesh in the fine mesh
regards,
Farzad
Hello Henrik
regards,
Farzad
