is there any difference between phi1t and pd(phi1,t).?I have to specify partial differential of phi1 w.r.t time(t)
Posted 14 janv. 2011, 04:36 UTC−5 Parameters, Variables, & Functions Version 3.5a 8 Replies
i have to solve a model including PDE general form equations. In source term i have to specify partial derivative of (phi1-phi2) wrt.time. first, i tried to simulate by specifying phi1t-phi2t. It didn't work.
if i specify the model with operator pd(phi1,t), my simulation is running in place of phi1t.
Could you please tell me why is this happening?. I am in a confusion weather my simulation is giving correct results or not.
thanks
ganesh
I suspect this is depending if you have selected or not the "time derivatives on" in the solver settings.
COMSOL operates sometimes differently in 3.5 and v4 (and you have not mentionned in which version you are).
In anycase check all GUI of the solver settings (an sequencing) somewhere there is a "time derivative" check box
It could be (without really knowing for sure) that there might be some differences when the "phi1t" is evaluated and the "d(phi1,t)" is done, but I do not beleive it is very different
thanks for reply.
My version is 3.5a.
I have turned "include time derivative" on in out put of solve manager. Still I am facing the same problem. problem is solvable when i give pd(phi1,t) pd(phi2,t) in place of phi1t, phi2t.
is phi1t equivalent to ordinary derivative d(phi1,t) or partial derivative pd(phi1,t)?
regards
ganesh
If phi1 is a dependent variable, phi1t and p(phi1,t) are equivalent but pd(phi1,t) is 0.
With the pd operator (contrary to the d operator), phi1 is considered independent of anything but itself. For example,
d(u+x,x) equals ux+1 whereas pd(u+x,x) equals 1.
The "Include time derivatives" setting in version 3.5a affects the output from the COMSOL simulation only. By storing the time derivatives you allow for more accurate interpolation of time derivatives; without including the time derivatives, the evaluation of second-order time derivatives like utt returns 0.
Magnus Ringh, COMSOL
thanks for the info, I see I need to refresh my d(), pd() operator use again, an check too that the v4 way is understood. I do not expect this to have canged, apart that I have noticed that the "save time derivatives" is "on" by default in v4.1
Hi, Magnus Ringh
can I use d(a, b) to represent da/db in comsol: (1) if "a" is not an dependent variable and "b" is not an independent variable; (2) if "a" is not an dependent variable but "b" is an independent variable; (3) if "a" is an dependent variable but "b" is not an independent variable?
thank you!
Thanks for the reply.
I have tried with p(phi1,t).But, COMSOL says its unknown function. If phi1 is a dependent variable, is it sufficient to represent phi1t as partial derivative wrt t? is d(phi1,t) represents the ordinary derivative?
In the quick reference book of multiphysics help, it was given about pd(f,x) as
"Differentiation operator. Differentiation of f with respect to x. No chain rule for dependent variables."
Could you please tell about this?
Ganesh
I believe p() is a typo and it's to be understood as d().
Check also the doc p79 of the user manuel v4.1 on "Differentiation Operators", or p163 in the 3.5a doc (user) guide.pdf
thanks for help..
regards
ganesh
Suggested Content
- KNOWLEDGE BASE BDF, Generalized Alpha, and Runge-Kutta Methods
- FORUM specify by vectorized view in 3D plots
- FORUM Differential Capacitance Calculations
- FORUM Solving Partial Element Equivalent Circuit (PEEC) formulation in COMSOL
- BLOG Guidelines for Equation-Based Modeling in Axisymmetric Components
