Spatially graded index / graded material properties
can anyone of you tell me if it is possible to define a graded index in comsol?
It seems as if sth. like this has been done in www.comsol.se/academic/papers/2871/
But how? Is it simply possible to use the coordinates as variables in the definition of global parameters for the dielectric properties?
This would mean, is just something like
parameter n
definition: factor * x
possible to achieve (simplified) a linear gradient of n over the geometric x dimension?
I would be happy about help.
Best regards
Arian
8 Replies Last Post 21 févr. 2013, 15:00 UTC−5
Posted: 1 decade ago 14 janv. 2011, 06:59 UTC−5
I'm not sure I'm getting exactly what you need, but generally you can use formulas in all (almost) fields of COMSOL, so why not rty it out on a simple verifiable example. Then it should be OK for a complex one ;)
Hi I'm not sure I'm getting exactly what you need, but generally you can use formulas in all (almost) fields of COMSOL, so why not rty it out on a simple verifiable example. Then it should be OK for a complex one ;) -- Good luck Ivar
Posted: 1 decade ago 17 janv. 2011, 10:01 UTC−5
Dear Ivar,
the complexity is not my problem.
I just wonder how to refer to a spatial variable like x, y or z (cartesian) in a formula for a parameter.
Do you know, where to search for an answer?
Best regards
Arian
Dear Ivar, the complexity is not my problem. I just wonder how to refer to a spatial variable like x, y or z (cartesian) in a formula for a parameter. Do you know, where to search for an answer? Best regards Arian
Posted: 1 decade ago 17 janv. 2011, 10:37 UTC−5
there was a discussion, if I remember right, on one of the other treads (I'm seeing too many ;) with a reply from COMSOL I believe
Hi there was a discussion, if I remember right, on one of the other treads (I'm seeing too many ;) with a reply from COMSOL I believe -- Good luck Ivar
Posted: 1 decade ago 20 janv. 2011, 18:16 UTC−5
Thanks so far, I am still working on it... I found something but it did not really match my problems. I think, I will dive a bit deeper into this stuff. Unfortunately I find other people's results which must base on sth. like this but no explanation anywhere... but maybe I have simply not yet searched long enough. When I find a solution I will post it.
Best regards
Arian
Thanks so far, I am still working on it... I found something but it did not really match my problems. I think, I will dive a bit deeper into this stuff. Unfortunately I find other people's results which must base on sth. like this but no explanation anywhere... but maybe I have simply not yet searched long enough. When I find a solution I will post it. Best regards Arian
Posted: 1 decade ago 7 avr. 2011, 09:00 UTC−4
Dear Arian,
I'm also interested about the RI variation profile as that of the the graded one. If you have got what you were looking for pls inform.
Partha
Dear Arian, I'm also interested about the RI variation profile as that of the the graded one. If you have got what you were looking for pls inform. Best regards, Partha
Posted: 1 decade ago 8 juil. 2011, 15:48 UTC−4
I am also very interested. did you find a solution?
I am also very interested. did you find a solution? Thanks
Posted: 1 decade ago 15 nov. 2011, 03:55 UTC−5
You need to design several circles with gradient index. Or you can define the refractive index profile function for a core region.
SK Varshney
You need to design several circles with gradient index. Or you can define the refractive index profile function for a core region. SK Varshney
Posted: 1 decade ago 21 févr. 2013, 15:00 UTC−5
I'd figure it out and I'm posting it just for the record:
Expand the material node and create a function (right click) under the sub-node "Refractive index". After that, you can call the function inside this node by using the sintax:
functionName(param1, param2, ..., paramN)
hope this helps.
cheers,
Felipe BM
I'd figure it out and I'm posting it just for the record: Expand the material node and create a function (right click) under the sub-node "Refractive index". After that, you can call the function inside this node by using the sintax: functionName(param1, param2, ..., paramN) hope this helps. cheers, -- Felipe BM
