Parametrized maximum mesh size
I would like to know if it is possible to parametrize the maximum mesh size. I've tried to enter function in the max. mesh size field, but it didn't work.
My problem is the following: I'm modeling a media which permittivity is spatially increasing : in order to be correct, the mesh quality of this media should also increase as the permittivity, because the wavelength decrease.
I would avoid to define many region which a differ max mesh size for each of them...
A good example should be a rectangle which its mesh quality increasing with the x direction...
5 Replies Last Post 13 janv. 2011, 13:01 UTC−5
Posted: 1 decade ago 13 janv. 2011, 04:34 UTC−5
have you tried to put a variable in the max mesh size of your 4.1 module, There are some examples around on parametrized mesh size, so some way must be possible
Hi have you tried to put a variable in the max mesh size of your 4.1 module, There are some examples around on parametrized mesh size, so some way must be possible -- Good luck Ivar
Posted: 1 decade ago 13 janv. 2011, 04:52 UTC−5
Yes, I've tried to put a parameter in the max mesh size field, for example 'x' (then the max mesh size should increase as 'x'), but I does not work. Error is : "Unknown model parameter."
[QUOTE] have you tried to put a variable in the max mesh size of your 4.1 module, There are some examples around on parametrized mesh size, so some way must be possible [/QUOTE] Yes, I've tried to put a parameter in the max mesh size field, for example 'x' (then the max mesh size should increase as 'x'), but I does not work. Error is : "Unknown model parameter." Best regards,
Magnus Ringh COMSOL Employee
Posted: 1 decade ago 13 janv. 2011, 05:33 UTC−5
The mesh parameters cannot depend on the space coordinates (such as x), but in version 4.1 you can use global parameters for a parameterized mesh size. See the following downloadable example from the COMSOL Support Knowledge Base:
www.comsol.com/support/knowledgebase/1103/
It shows how to parameterize the mesh size so that the mesh resolves the wave for varying wavelengths.
Magnus Ringh, COMSOL
Hi, The mesh parameters cannot depend on the space coordinates (such as x), but in version 4.1 you can use global parameters for a parameterized mesh size. See the following downloadable example from the COMSOL Support Knowledge Base: http://www.comsol.com/support/knowledgebase/1103/ It shows how to parameterize the mesh size so that the mesh resolves the wave for varying wavelengths. Best regards, Magnus Ringh, COMSOL
Posted: 1 decade ago 13 janv. 2011, 07:03 UTC−5
OK, but in this case the max mesh size is constant for a domain, which not I want. So I guess that in my case the only way to proceed is to make a lot of different layers of increasing mesh density.
Thank your for your answers;
[QUOTE] The mesh parameters cannot depend on the space coordinates (such as x), but in version 4.1 you can use global parameters for a parameterized mesh size. [/QUOTE] OK, but in this case the max mesh size is constant for a domain, which not I want. So I guess that in my case the only way to proceed is to make a lot of different layers of increasing mesh density. Thank your for your answers; Best regards,
Posted: 1 decade ago 13 janv. 2011, 13:01 UTC−5
you can use a log or exp progressing shape distribution of the nodes on the lateral edges, and like that get un uneven distribution
Hi you can use a log or exp progressing shape distribution of the nodes on the lateral edges, and like that get un uneven distribution -- Good luck Ivar
