different between Calibrate for general physics and dynamic mesh
Hi all
I have a simple question about the element size. What is the different between Calibrate for general physics and
dynamic mesh?. And are they effect in the results?? . Is the second one especially for fluid flow??
2 Replies Last Post 13 janv. 2011, 02:15 UTC−5
Posted: 1 decade ago 13 janv. 2011, 01:49 UTC−5
I assume you are in 4.1 then, there the new mesher has added some "auto mesh size by estimation from physics features" They works rather nicely, but you can always (and must often for complex model) fine tune by hand
Hi I assume you are in 4.1 then, there the new mesher has added some "auto mesh size by estimation from physics features" They works rather nicely, but you can always (and must often for complex model) fine tune by hand -- Good luck Ivar
Posted: 1 decade ago 13 janv. 2011, 02:15 UTC−5
Thanks for your reply. Actually my question Is dynamic mesh for only fluid flow case?
