Muthukrishnan Subramaniyan
11 janv. 2011, 08:40 UTC−5
Please give me some particle tracing hints or references as well.
Thanks.
Thanks.
11 janv. 2011, 09:01 UTC−5
I think you need to describe your model more precisely or upload the model file. For now I don't understand what your model looks like. What are open subdomains?
Regards
Edgar
Regards
Edgar
11 janv. 2011, 09:27 UTC−5
I am not able to upload my model due to file size error and I cant zip it and send as well.
I will try to explain in a better way.
I am trying to analyze ionization and particle tracing in 3D .
My model consists of,
1. A coil spring of 9 turns - Anode.
2. A Tungsten wire - Cathode.
they are separated by some distance 'd' , where d can be varied.
I have imported these subdomains from CAD. I have applied some voltage using boundary settings . Followed by Meshing and Solving, I am trying to visualize the electrical field between anode and cathode in the post processing mode using streamlines. and I am looking for particle tracing as well.
Now, in postprocessing - Boundary mode shows ' 0 ' voltage applied, thereby it is not showing the electrical field.
Moreover is it possible to generate the electrical field with this kind of model ?
Thanks in advance.
Thanks in advance.
11 janv. 2011, 09:35 UTC−5
Please skip open sub domains. I am trying to consider the coil spring which is not closed at the ends. Thats it.
11 janv. 2011, 09:41 UTC−5
Did you place your cathode and anode into some kind of surrounding air or vacuum domain? Can be a sphere around your assembly or a cylinder.
If you want to see the field between the electrodes you must model the space between them as well.
11 janv. 2011, 10:03 UTC−5
I have created a cube which surrounds the entire model and positioned in such a way that the model rest in the center of the cube.
The same settings works with two similar cylinders (Anode and cathode) and I am able to visualize the electrical field.
- The one from the model library( Potential between cylinders) works in the same way.
Cheers,
Muthu
Cheers,
Muthu
