Optimizating COMSOL model by using a solver implemented in MATLAB
Dear all:
I want to ask for your help regarding the problem I am dealing with right now.
I implemented a COMSOL PDE model with moving boundary and now I want to connect it with an optimization solver implemented in MATLAB in order to perform optimal control of the process, i.e. to pass a vector of control variables discretized in time from the MATLAB solver to COMSOL, to run it and to obtain certain output variables that will allow to calculate a given objective function which has to be minimised. Which is the best way to do it? Via exporting the COMSOL model as a Simulink block? Some experience using LiveLink? Other ideas?
I hope someone of you had the same problem in the past and could help me.
Thank you very much in advance!
Best regards
Luis T. Antelo
1 Reply Last Post 11 janv. 2011, 11:52 UTC−5
Posted: 1 decade ago 11 janv. 2011, 11:52 UTC−5
you ave also the optimising toolbox in COMSOL, and i its a single variable, what COMSOL is doing is least square minimising. The book of Zimmermann gives several examples
Hi you ave also the optimising toolbox in COMSOL, and i its a single variable, what COMSOL is doing is least square minimising. The book of Zimmermann gives several examples -- Good luck Ivar
