Weak form boundary - details
Hi all,
I come back here because I have some question about Weak form
Boundary.
I have a boundary integral equation int_{boundary)u(s)=-u(s).
I use the Weak form boundary to find the unknown u(s) definined at
the surface of the geometry.
Brievely, how does comsol do to solve it by using FEM.
I think that comsol just expand the solution u in a shape functions set
then solve the equation system obtained for each node of the mesh.
I am right ? How does play the test function ?
Someone can explain to me the different steps
used by comsol to solve a problem using
Weak form boundary ?
Thank you very much !
Sullivan
4 Replies Last Post 4 févr. 2011, 09:18 UTC−5
Posted: 1 decade ago 7 janv. 2011, 08:29 UTC−5
That's a kind of question with a book-sized answer ... you should check the doc: "understanding FEM". There are many facts explained very well of how COMSOL works in detail.
A few remarks (thats how I understand FEM):
Using the weak form is the way of FEM.
COMSOL does not "expand" the solution to shape functions - shape functions are part of the approximations.
COMSOL solves the linear / linearized (Jacobian-)matrix.
Last but not least, the solution produced by FEM (and therefore by COMSOL) is the not the solution "for each node" - it is the "integration-averaged" (-> weak form) solution over the whole element(s).
Best regards.
That's a kind of question with a book-sized answer ... you should check the doc: "understanding FEM". There are many facts explained very well of how COMSOL works in detail. A few remarks (thats how I understand FEM): Using the weak form is the way of FEM. COMSOL does not "expand" the solution to shape functions - shape functions are part of the approximations. COMSOL solves the linear / linearized (Jacobian-)matrix. Last but not least, the solution produced by FEM (and therefore by COMSOL) is the not the solution "for each node" - it is the "integration-averaged" (-> weak form) solution over the whole element(s). Best regards.
Posted: 1 decade ago 7 janv. 2011, 09:13 UTC−5
there are a few interesting books, see:
www.comsol.eu/support/books/
In particular that of Zimmermann (older FEMLAB AND COMSOL 3.4) and the book of Edberg
but also
i.e. the three (to be 4 once) books of Francois Axisa (check by Amazon), on "Modelling of Mechanical Systems"
Hi there are a few interesting books, see: http://www.comsol.eu/support/books/ In particular that of Zimmermann (older FEMLAB AND COMSOL 3.4) and the book of Edberg but also i.e. the three (to be 4 once) books of Francois Axisa (check by Amazon), on "Modelling of Mechanical Systems" -- Good luck Ivar
Posted: 1 decade ago 11 janv. 2011, 05:27 UTC−5
Where can this document 'Understanding fem' be found?
Posted: 1 decade ago 4 févr. 2011, 09:18 UTC−5
It's delivered with your comsol distribution :)
Check the "reference guide" chapter 3 p. 483. (V3.5a)
It's delivered with your comsol distribution :) Check the "reference guide" chapter 3 p. 483. (V3.5a)
