7 janv. 2011, 04:09 UTC−5
I notice a few things:
1) you are still with the initial 4.1, get the PATCH on the main COMSOL site, there are still a few equation error in your version
2) your Bezier Polygone 6 is empty, I'm not sure it has any influence, but as a general rule, get rid of non used features, COMSOL is already complicated like that
3) I do not think you really need the infinite elements, your volume is already "large" like that, try just to disable the Infinite elements.
I believe the issue is that your ground is so far away "behind" the infinite value that you are missing a BC like that.
You should even use a finer mesh (or analyze the mesh density relation to the results)
If you turn on a Countour plot you will notice that your square is influencing the field shape by its corners. So I would advise to rather use a large circle centered on your cat, then your results would be even more precise over the hole domain. This is also worth a comment as it can have its importance in many simulation cases, the shape of "large" "infinite" domains are also important
One more:
Once you have replaced the two squares by a circle, then 1) subtract the cat from the circle, no need to mesh inside the cat, 2) then you inverse your system: a) put the cat boundary at GND, b) remove your charge and c) put 1000V around on the circle border. This will better show you the spiking effects, use extra fine meshing. (all without infinite elements OK
Note the potential around the spiky ears and tail, compare to the applied voltage !
Nice cat ;)
One more:
Nice cat ;)
7 janv. 2011, 04:31 UTC−5
Hi Again
Your solution is working in fact, but you should use a "general" Type infinite element, and not a cartesian, because your boxes are not centered on 0,0 and your Cartesian infinite domain conditions are defined at 0,0
You can also either center your 2 boxes on 0,0, or replace the infinite element center and use Cartesian. But then you will notice the effect of the corners
Again the shape of your infinite elements should be close to the one of your field for best reply
Hi Again
7 janv. 2011, 05:11 UTC−5
Hi Ivar
Thanks a lot for you fast and detailed response.
I will change the mentioned points.
Irina
Hi Ivar
Irina
22 août 2013, 05:03 UTC−4
How do you display the boundary identification which is very helpful to select the boundary in your graph window?
Thank you,
Qize,
Thank you,
Qize,
Jeff Hiller
COMSOL Employee
22 août 2013, 08:01 UTC−4
Hello Qie,
In the Model Builder, under Definitions>View, check the "Show geometry labels" checkbox.
Hello Qie,
22 août 2013, 12:11 UTC−4
Hi Jeff,
Thank you for your help,
with best regards,
Qize
Hi Jeff,
with best regards,
Qize
