Sum of square method
I have a Comsol model which generates me a curve. I have another curve corresponding to the measured data.
I want to find the difference between curve generated by Comsol and the curve corresponding to measured data.
And I dont want to use Comsol's optimization module. So this problem is a curve fitting problem except that I want to do it manually instead of making use of Comsol's optimization module.
Any pointers are appreciated
1 Reply Last Post 11 oct. 2016, 17:28 UTC−4
Walter Frei COMSOL Employee
Posted: 9 years ago 11 oct. 2016, 17:28 UTC−4
Hello Vishnu,
This may describe what you're looking for:
www.comsol.com/blogs/curve-fitting-of-experimental-data-with-comsol-multiphysics/
Best Regards,
Hello Vishnu, This may describe what you're looking for: https://www.comsol.com/blogs/curve-fitting-of-experimental-data-with-comsol-multiphysics/ Best Regards,
