Incremental rotation in an array
Posted 22 sept. 2016, 10:24 UTC−4 Simulation Apps, Geometry Version 5.2 2 Replies
I'm trying to create an array of objects along the axis of a cylinder, and also incrementally rotate each element of the array relative to the cylinder axis (e.g. array element1 rotated by 5 degrees, element 2 by 10 degrees and so on). The number of array elements is a parameter. Is there any way of doing the rotation in a single operation (I can manually create a number of rotate nodes, but it will be cumbersome)?
Hello Sharath Gopal
