Creeping flow sliding and moving wall
Posted 20 sept. 2016, 00:56 UTC−4 Fluid & Heat, Modeling Tools & Definitions, Parameters, Variables, & Functions, Structural Mechanics Version 5.1 0 Replies
Im using the creeping flow module to simulate a sphere in fluid that is translating along one axis (say y) and rotating about one axis (say z), simultaneously. I have successfully done both motions individually (translation with moving wall BC, rotation with sliding wall BC). How can I combine both these motions, since adding one wall node below the other overwrites the first?
Thank you,
Adam
Hello Adam Woodman
