2D Geometry
Dear all, hello!
I am working on the 2d fluid dynamics module. I have a particular width and length profile. Now i need to add a constant depth information as well in my model. Is it possible to add constant depth information in a 2d model. If yes, how?
Thanks alot for your help.
Adnan Haider
Germany
1 Reply Last Post 25 déc. 2010, 05:15 UTC−5
Posted: 1 decade ago 25 déc. 2010, 05:15 UTC−5
in 3.5a you should have the "Thickness" parameter in the domains window. In v4 there is a sub-node normally to adapt, per domain if required
Hi in 3.5a you should have the "Thickness" parameter in the domains window. In v4 there is a sub-node normally to adapt, per domain if required -- Good luck Ivar
