How to set a solution-depdendent vaiable?
Hi all,
I want to modeling the curing process of composites, and essentially, it is a transient heat transfer problem. But in my model, some material parameter will change with the temperature, and the temperature is the output result for this problem. So I wonder if there is any way that I can define those variables dependent on temperature. I tried to write these variables as a function of temperature,but it also said the temperature is not defined? I have attached my model and please help me check what's wrong with that.
Thank you very much!
Ge
1 Reply Last Post 2 sept. 2016, 10:45 UTC−4
Mao COMSOL Employee
Posted: 8 years ago 2 sept. 2016, 10:45 UTC−4
Hi Ge,
While waiting for other users to reply on the forum, you can also submit questions to support@comsol.com. COMSOL support team will be able to help you.
Mao Mao, PhD
COMSOL, Inc
Hi Ge, While waiting for other users to reply on the forum, you can also submit questions to support@comsol.com. COMSOL support team will be able to help you. Best regards, Mao Mao, PhD COMSOL, Inc
