Problem with imported BH curve
Hello everybody,
I'm pretty new to Comsol, but I think I already understand at least the basics ;)
I've got a working simulation file of a magnetic coil. The used material is not from the included library but modified using an external BH curve of the iron. Now I tried to modifie the material using other BH curves I found on the Internet. I didn't change anything on the geometry, I only deleted the old BH data and imported the new data. I got the new BH curves from www.femm.info/wiki/softmagneticmaterials.
Now I always get errors like:
"No solution found.
Divergence of linear iterations.
Solution does not converge." (Translated)
or
"No soluton found.
Maximum number of Newton-iterations reached.
Does anyone of you have an idea what could help solving my problem?
I'd appreciate any hint.
Greetings
JO
EDIT: Topics added
1 Reply Last Post 15 août 2016, 06:45 UTC−4
Posted: 9 years ago 15 août 2016, 06:45 UTC−4
If you have imported new data, you might want to revisit the boundary conditions. That might be causing the non-convergence.
Mahvash
Hi, If you have imported new data, you might want to revisit the boundary conditions. That might be causing the non-convergence. Best, Mahvash
