Temperature effect on Eigenfrequency
Hello!
I am a master student doing a simulation of a ophononic crystal in Comsol 5.2.
I use Solid mechanics and heat transfer in solids moduls.
The model is a simple phononic crystal, square lattice, that have a boundaty heat source and surface emmision. I have study 1 to solve for eigenfrequency and study 2 to solve for heating, study 2 is time dependent.
The results looks good i get the complete band structure and i can see heating of the model.
The problem i have is to connect this two studies to eachother, i want to see how the band stucture change when the model gets heated.
For example, t=0, T=293K results in one band structure
t=5, T=350K should result in another looking band structure and so on.
With kind regards
Olivier
1 Reply Last Post 10 août 2016, 11:08 UTC−4
Niklas Rom COMSOL Employee
Posted: 9 years ago 10 août 2016, 11:08 UTC−4
Hi Oliver,
this is indeed not straightforward. The reason is that the eigenfrequency solver cannot take dynamic data sets as input (for example a vector of time steps). It can only take one linearization point. Luckily, you can work around this by clever usage of a parametric sweep. See the attached example:
cds.comsol.com/mg/a57ab42a688d02.zip
Estimated size: 39.8 MB
This link expires August 17, 2016. Please make sure to download before that date.
Included files:
- transient-eigenfrequency.mph
Niklas
Hello!
With kind regards
Olivier
Hi Oliver, this is indeed not straightforward. The reason is that the eigenfrequency solver cannot take dynamic data sets as input (for example a vector of time steps). It can only take one linearization point. Luckily, you can work around this by clever usage of a parametric sweep. See the attached example: ------------------------------------------- http://cds.comsol.com/mg/a57ab42a688d02.zip Estimated size: 39.8 MB This link expires August 17, 2016. Please make sure to download before that date. Included files: - transient-eigenfrequency.mph ------------------------------------------- Niklas [QUOTE] Hello! I am a master student doing a simulation of a ophononic crystal in Comsol 5.2. I use Solid mechanics and heat transfer in solids moduls. The model is a simple phononic crystal, square lattice, that have a boundaty heat source and surface emmision. I have study 1 to solve for eigenfrequency and study 2 to solve for heating, study 2 is time dependent. The results looks good i get the complete band structure and i can see heating of the model. The problem i have is to connect this two studies to eachother, i want to see how the band stucture change when the model gets heated. For example, t=0, T=293K results in one band structure t=5, T=350K should result in another looking band structure and so on. With kind regards Olivier [/QUOTE]
