Can the elastic matrix be modified by oneself in Solid Mechanics model?
We all know that elastic module E and Possion's ratio mu are needed in Solid Mechanics model. Then, the elastic matrix is assembled according to both of them. however, a NEW elastic matrix can be assembled by oneself ? In other words, different domains own different constitutive relations in a model.
Thanks a lot!
2 Replies Last Post 18 oct. 2016, 04:48 UTC−4
Posted: 9 years ago 22 juil. 2016, 13:20 UTC−4
If you change the Linear Elastic material model from Isotropic to Anisotropic, the input is the elements of a general elastic constitutive matrix.
Henrik
Hi, If you change the Linear Elastic material model from Isotropic to Anisotropic, the input is the elements of a general elastic constitutive matrix. Regards, Henrik
Posted: 9 years ago 18 oct. 2016, 04:48 UTC−4
Thank you very much! This problem had been solved.
