Quality factor in 3D
Posted 8 déc. 2010, 09:08 UTC−5 RF & Microwave Engineering, Studies & Solvers Version 3.5a 12 Replies
I am working on a 3D geometry and trying to obtain eigenfrequencies and quality factor in RF module. But it seems, eventhough Comsol can find the eigenfrequencies correctly, quality factor values changes depending on the boundary conditions used. Since it is an eigenfrequency analysis, is that normal to see different quality factor values when the boundary conditions are changed? Which boundary conditions should I use?
Anyway, I've also used PML but in this case, I start getting memory error sooner or later. Is there any way tor prevent this? Actually, my geometry has a symmetry to the x-axis, so it would be great if there is such a way to set a symmetry axis and compute only one half of the geometry.
I would appreciate any help/suggestions. Thanks in advance,
Elif
a quality factor is linked to damping and by default there is none (or perhps some numerical damping physics dependent) so the Q factor will essentially depend on what you defne in the "damping" material property term.
What are you using ?
What do you mean by damping? If you mean whether I use lossy material, I don't use any. Materials that I use all have real valued properties.
then how can you defin a "Q value" of a resonance if you do not have any "damping" ?
A FEM pogramme will give you the eigenfrequencies depending on (for an isoptropic marial) E, nu, rho (Young modulus, Poisson and density) and the geometrical shape (hence I.. inertia tensor) nothing more, the true Q factor of such resonnaces is not defined, the peaks are infinitely long and narrow (to the numerical damping limit).
So if you need a true Q factor you must define some damping.
However, with 4.1 you have access to the mass participation factors which gives you the relative energies of the different modes w.r.t the three spatial directions x,y,z (unfortunately these are not resolved for the three rotations) the way the mass participation factors are defined are that the sum of the square of each mode "mass participation" factor (for all modes) sum up to the total mass (per direction, and for the rotations it would be summing to the total inertia in the respective directions). Check the doc and the eigenfrequency solver sub-node to select the correct normalisation
The Q-factor values that I have found are calculated by Comsol itself with this parameter, Qfact_rfw. Why do you think that they are not the true Q-factors? What am I missing here? How should I be calculating them in order to obtain the true ones?
sorry for the confusion, I'm not saying that COMSOL is not calculating correctly.
If you feed in correct damping values (or in rf corret complex indexes) then the damping is present and the Q factors as defined are there. Depending, on the physics though the material "damping" properties are not always that well known. But for RF and optics this is rather the case.
Pls note that in RF there are different ways to enter the material properties, and if you operate with material index of refraction there is a particular sign convention that COMSOl uses, while there are 2 different common ones in the litterature, just check that you use the same with the same sign for the complex index value.
Again nothing wrong, it's only that one need to know that there are different representations and chack that we all (and COMSOL) uses the same. This applies also for PZT material tensor properties, COMSOL follows the IEEE convention, that is different from the traitional structural convention.
Thanks for your quick reply.
In my model I don't use any material that have complex material properties. The refractive indices are all defined in real values. So I obtain real-valued eigenfrequencies, but even in this case Comsol can provide Q-factors which I have found them rather small but this is another thing. What way should I follow in order to calculate Q-factors? and also have another thing to ask that in which boundary configuration I can obtain the correct Q-factor values?
Elif
It is a 3D cavity modelling. I am trying to find the correct boundary conditions because as I change the boundaries, q-factor values change as well.
Actually i've encountered similar problem when modeling 3D cavity in comsol.
After weeks of such comsol simulations my conlusion are:
1. I dont think one should trust the Qfact_rfw given by comsol, it is no clear what it means and what are the source of the loses in general and specificaly for loss-free materials and PEC boundary conditions. It also tends to change with: meshing, air gap between the cavity and the bounadries and etc.
2. to me it seems that the best way to simulate cavity and loses is
A. not in comsol.
B. in case you are using comsol use: large air gap, PML domain after it and PEC boundary conditions at the end of the PML layer.
Elif, Jones and others- I would appriciate your feedback and opinion.
I have some problms to follow fully, but I agree one shhould always be suspicious and verify all results even from COMSOL. Now Q factors, for me, are only energy loss related, and the way FEM is set up (hence also COMSOL as a FEM tool) is that you have some numerical "loss de to the solving and number representation" mostly very small (provided your mesh is OK), you have then the material loss and the model / physics simplification which might introduce losses.
If you are sure you have a perfectly balance energy value for your physics of your model it remains the material loss effects, but most material data are reported "without losses".
Hence missing/incomplete input, => not really reliable output
thank you
