crash because of java
I install the comsolV35a in debian-X64 system , when I open the comsol, it will easily crash. The error are as following. Could anyone give help for this issue? Thanks in advace.
Zhan
_______________________
An unexpected error has been detected by Java Runtime Environment:
# SIGSEGV (0xb) at pc=0x00007f1c164e5e2b, pid=25428, tid=139757092980496
# Java VM: Java HotSpot(TM) 64-Bit Server VM (10.0-b22 mixed mode linux-amd64)
# Problematic frame:
# C[thread 139757063493392 also had an error] [libpthread.so.0+0xee2b]
raise+0x2b
# An error report file with more information is saved as:
# /usr/local/comsol35a/bin/hs_err_pid25428.log
# If you would like to submit a bug report, please visit:
# java.sun.com/webapps/bugreport/crash.jsp
./comsol: line 2168: 25428 Aborted ${MPICMD} ${JAVA} ${JVMARGS} ${CLTMPARG} -classpath ${FLCP} ${SHOWVERSION} ${MAINCLASSARG} ${APPLARGS}
zhanyh:/usr/local/comsol35a/bin# ./comsol -gcc332
# An unexpected error has been detected by Java Runtime Environment:
# SIGSEGV (0xb) at pc=0x00007f82744190be, pid=25551, tid=140198257297168
# C [libGL.so.1+0x5b0be] XF86DRIQueryVersion+0xae
# /usr/local/comsol35a/bin/hs_err_pid25551.log
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
./comsol: line 2168: 25551 Aborted ${MPICMD} ${JAVA} ${JVMARGS} ${CLTMPARG} -classpath ${FLCP} ${SHOWVERSION} ${MAINCLASSARG} ${APPLARGS}
1 Reply Last Post 7 janv. 2012, 13:17 UTC−5
Hello Zhanyh Yh
Posted: 1 decade ago 7 janv. 2012, 13:17 UTC−5
Hi, in case someone else still/also has that problem: One solution seems to be to export the env var LIBGL_ALWAYS_INDIRECT=1. This helped me. The problem is actually the ATI/AMD driver as far as I've read it, this env var seems to be a working workaround.
