Numerical derivative
I am using a scalar variable f(T) in a transient heat transfer model. Since the model is transient, T is dependent on time. How can I calculate the derivative df/dt (numerically or analytically)?
I need to know the derivative df/dt, since I want to specify another function g(df/dt).
Thanks in advance
Ivan
3 Replies Last Post 3 déc. 2010, 01:26 UTC−5
Posted: 1 decade ago 2 déc. 2010, 01:30 UTC−5
in 4.1 check the doc about the "prev()" operator. Do an indexed search on the pdf doc.
I notice that 90% of the replies on the forum can be solved by a quick search on the pdf doc.
I find too that the doc are dense and one need to read them several times, but in fact about everything is in there (for 3.5a =< doc >= 4.1 ;)
Hi in 4.1 check the doc about the "prev()" operator. Do an indexed search on the pdf doc. I notice that 90% of the replies on the forum can be solved by a quick search on the pdf doc. I find too that the doc are dense and one need to read them several times, but in fact about everything is in there (for 3.5a =< doc >= 4.1 ;) -- Good luck Ivar
Posted: 1 decade ago 2 déc. 2010, 13:30 UTC−5
I am currently using v3.5, there the prev() command is not available. I tried the diff() command, but that one holds only if there is an explicit dependence on time.
Best
Ivan
Hi, I am currently using v3.5, there the prev() command is not available. I tried the diff() command, but that one holds only if there is an explicit dependence on time. Best Ivan
Posted: 1 decade ago 3 déc. 2010, 01:26 UTC−5
indeed v4 has among many other improvements the prev() operator.
I have decided currently to use the v4.1 for "serious/client" work, and have decided to forget 3.5a. The main issue I still have is the lack of a "summary report", but by doing a file reset and save the model as a ".m" file I have a readable trace (for me), apart that my clients are not able to understand it ;)
Hi indeed v4 has among many other improvements the prev() operator. I have decided currently to use the v4.1 for "serious/client" work, and have decided to forget 3.5a. The main issue I still have is the lack of a "summary report", but by doing a file reset and save the model as a ".m" file I have a readable trace (for me), apart that my clients are not able to understand it ;) -- Good luck Ivar
