Time Dependent Optimization
Hi All,
I am working on topology optimization of electric machine, I have a question about how does time dependent optimizaiton solver work. I want to do the topology optimization within certain rotation angle, in this case I need the sensitivity analysis of the objective function. I am modeling the rotating machine by using time dependent solver, and then do the optimization under time dependent solver. I am wondering if the optimizer solves the objective function once every each time step like a 'for loop' or solves the sensitivity with respect to all rotor angles? The sensitivity can be done internally of the optimizer, but I am not sure which way does it work. I appreciate all help or comments. Thank you very much.
Feng
1 Reply Last Post 3 mars 2017, 08:26 UTC−5
Hello Feng Guo
Posted: 8 years ago 3 mars 2017, 08:26 UTC−5
I have the same question with ,I want to know that whether you have solved it, I want ask you some question, my Email:zhongying_xu@163.com,thank you very much!
