material vs wavelength
hi to all
how can i define a material which the refractive index is varied with the wavelength by formulala or numbers?
1 Reply Last Post 1 déc. 2010, 02:55 UTC−5
Posted: 1 decade ago 1 déc. 2010, 02:55 UTC−5
normally you make tables and COMSOL interpolates from your measurement data, but analytical functions are also possible, check the doc on materials and the material DB
Hi normally you make tables and COMSOL interpolates from your measurement data, but analytical functions are also possible, check the doc on materials and the material DB -- Good luck Ivar
