Error when using Livelink for Matlab
I need to call a Matlab function and it works fine if i try it in the simple Matlab Command Window, but when i run the simulation and try to pass probe values to the function (I use it as objective function in the optimisation module) there is an error message: "Error in sweep. Error. Unbalanced or unexpected paranthesis or bracket."
I think it is very strange because the function works in Matlab and in the Matlab command window that Comsol opens up.
Br Rasmus
2 Replies Last Post 21 juin 2016, 05:39 UTC−4
Posted: 9 years ago 20 juin 2016, 12:18 UTC−4
Is there a a maximum number of variables i can pass to the matlab function? I need to pass a lot of coordinates and i couldn't find another way than to make each x-, y- and z-coordinate individual inputs.
Posted: 9 years ago 21 juin 2016, 05:39 UTC−4
Hi Rasmus
Comsol 5.2a doesn't have any limits imposed on how many arguments you can have to Matlab function called by Comsol. Previous versions had a limit around 25.
You can send your model to support@comsol.dk and someone can have a look at the problem.
Lars Gregersen
Comsol Denmark
Hi Rasmus Comsol 5.2a doesn't have any limits imposed on how many arguments you can have to Matlab function called by Comsol. Previous versions had a limit around 25. You can send your model to support@comsol.dk and someone can have a look at the problem. -- Lars Gregersen Comsol Denmark [QUOTE] Is there a a maximum number of variables i can pass to the matlab function? I need to pass a lot of coordinates and i couldn't find another way than to make each x-, y- and z-coordinate individual inputs. [/QUOTE]
